7 members (Philipj, CharlieF, CATMAN, klhansen, fonz8261, Shade Baby, Phak1), 84 guests, and 2 robots.
Topics128,153
Posts1,056,842
Members48,456
I am in the process of a frame off restoration of my 1965 C10. I plan on using 2 1/2" drop spindles on the front and 3" drop coil springs on the rear. From everything I have read the original tracking arm will still function properly as long as the drop coil springs do not exceed a 4" drop. Can anyone confirm this is correct?
Just a note that I would be careful with which drop springs you get. A lot of drop springs use smaller diameter steel and have much less load carrying capacity.
My 46 GMC on Photobucket
The factory trailing arms, are still fully functional with 3" drop springs in the rear. I believe you must use lowering shocks, in conjunction with 2-1/2" front drop coils & 3" drop coils in the rear. Verify this with the drop coil spring provider. Good luck with your '65 Chevy truck project.
