2 members (Kilted54, UtahYork), 72 guests, and 2 robots.
Topics128,196
Posts1,057,392
Members48,469
If I feather the gas while pushing in the clutch and pressing brake pedal I can manage. I just changed sparkplugs and cleaned off the rotor. Still no help also increased the idle. When this trip finally ends I will pull off the carb and spray it clean. Getting frustrated. Just wondering if I am overlooking an obvious.
This is a 235 single carb stock engine.
Would adjusting the valves do any good?
Intake leak?
Did it run fine before spark plug change and rotor cleaning?
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
