| | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | If I feather the gas while pushing in the clutch and pressing brake pedal I can manage. I just changed sparkplugs and cleaned off the rotor. Still no help also increased the idle. When this trip finally ends I will pull off the carb and spray it clean. Getting frustrated. Just wondering if I am overlooking an obvious.
This is a 235 single carb stock engine. | | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | Would adjusting the valves do any good? | | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Did it run fine before spark plug change and rotor cleaning?
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
