0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Hi List,
forgive me for asking such a silly question but I am 5000 miles from my truck and trying to find the right flare wrenches to do some brake work when I get home. Can someone tell me the size of the hex on the Rubber brake lines?
thanks,
joe
1955 First Series 3100
| | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | 3/16" steel lines have a 3/8" flare nut, and the rubber flex lines will have 5/8" wrench sizes on both ends. The line coming from the master cylinder to the front and rear T-blocks will probably be 1/4" diameter tubing with a 7/16" nut. The upper end of a rubber flex line will also be locked into a bracket on the frame that restricts it from turning, but I always use a flare nut wrench as a backup anyway.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Hey Joe, Its a good idea to state what the Make, Model & Year of the vehicle you are asking the question about. I assumed its a Chevrolet 1955 1st series 3100 1/2 ton truck. According to the 1929-1957 Master Parts Catalog Group number 4.680 Hose Assembly, Hydraulic Brake Hose Hex size is 7/16 Thanks, | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thank you Gentlemen, that is exactly what I needed to know.
Joe
