4 members (J Lucas, klhansen, kurbside bolter, JoergK.), 161 guests, and 1 robot.
Topics128,266
Posts1,058,369
Members48,485
#1001564 01/24/2014 6:47 AM
Is the Clark 5 speed the same bolt pattern as a small block or big block Chevy if my 292 doesn't fire I might yank it in favor of a v8a
Jdude
What are you working on?
Riding in the Passing Lane
The bell housing that fits the 292 will fit the V-8.
1972 Chevy c10 Cheyenne Super
Which Clark 5 Speed?
Actually Chevy and GMC both used the same bolt pattern for all the manual gear boxes. Only change was the hole for the front bearing retainer.
Not sure which year the change came into play. I think it was when the 4 speed changed from the SM420 to the SM465, (just a guess) the bearing retainer hole was enlarged. But the 4 hole bolt pattern remains the same for 4 speed or 5 speed.
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
GM transmission bolt pattern may be the same but the heavier duty setups often used larger diameter flywheels than the same engine in a small truck, bigger clutches. And where you can get into trouble trying to swap is longer (often larger too) input shafts in the transmission.
You can machine a spacer or if available swap the smaller input shaft to get the transmission from a big truck to fit a small, or rather shallow, bellhousing.
Other way around putting a small truck transmission with common input shaft on a big truck bellhousing can result in the input shaft being too short to reach the pilot bearing, might not be anything to do about that... swap input shafts if you can.
Advance Adapters may have the spacer and I'm sure they have the input retainer adapter... what is it, 4-11/16" to 5-1/8" ?
•1952 Chevrolet 3800 pickup
---All pictures---
it is for my 51 gmc 450 3 ton with a 292 chevy six
Jdude
A 450 series should have room for the larger clutch housing and 60 series Chev used the big clutch housing. Which clutch housing do you have?
I don't know I could post a pic if it might help.
Jdude
I am close to you and mite be able to help. If you have a 292 someone has already done an engine swap on your truck.As wrenchbender stated above the belhousing that is bolted to your 292 will bolt to a small block, big block or 90* V6 Chevy.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
