7 members (Bill Hanlon, baldeagle, Otto Skorzeny, tonyt, JW51, gswbbc, 55shaker),
84
Mod | | | Forums66 Topics128,040 Posts1,055,475 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | I read somewhere that all 47-53 truck/suburban/ panel transmission where 3 speeds if they were on the column and 4 speed if they the manual up through the floor.
Can anyone confirm if that is the case.
Thank you in advance Marc | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | That's pretty accurate, although some of the floor-shifted transmissions might have been 5 speeds on the bigger rigs. On anything basically pickup-sized, the SM 420 4 speed was the floor-shift model. Jerry
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy youngrodder, yes that is the case as far as I have seen, hope that helps. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | . . . all 47-53 truck/suburban/ panel transmission where 3 speeds if they were on the column and 4 speed if they the manual up through the floor."For Chevrolet trucks 47-53 that is correct. Only one three-speed on the column and one 4-speed on the floor was available as GM factory equipment 47-53. Big GMC trucks are a different matter, as Jerry posted. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | 1947/1948 came with three speed on the floor. Parking brake handle was next to the floor shifter. | | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | Thanks everyone, that is the answer that I was hoping for.
Marc | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | That's the problem with mid year vehicles. I am never sure what to call it so I call it both. It was only available on the floor when the truck was first released in late 1947. There are several details that are different on this release than from other years. Even the the gauges and speedometer were in a different housing. | | |
