4 members (49nut, Steelonsteel, klhansen, Shardean), 73 guests, and 4 robots.
Topics128,022
Posts1,055,376
Members48,420
#1001626 01/24/2014 4:45 PM
Y
Y Offline
I read somewhere that all 47-53 truck/suburban/ panel transmission where 3 speeds if they were on the column and 4 speed if they the manual up through the floor.
Can anyone confirm if that is the case.
Thank you in advance
Marc
That's pretty accurate, although some of the floor-shifted transmissions might have been 5 speeds on the bigger rigs. On anything basically pickup-sized, the SM 420 4 speed was the floor-shift model.
3B Offline
Hy youngrodder, yes that is the case as far as I have seen, hope that helps.
. . . all 47-53 truck/suburban/ panel transmission where 3 speeds if they were on the column and 4 speed if they the manual up through the floor."
For Chevrolet trucks 47-53 that is correct. Only one three-speed on the column and one 4-speed on the floor was available as GM factory equipment 47-53. Big GMC trucks are a different matter, as Jerry posted.
1947/1948 came with three speed on the floor. Parking brake handle was next to the floor shifter.
Y
Y Offline
Thanks everyone, that is the answer that I was hoping for.
Marc
Thanks for the partial correction, George, I forgot about 1947.
The 1947 trucks' 3-speed shifter was on the floor.
The 1948 trucks' 3-speed shifter was on the steering column.
That's the problem with mid year vehicles. I am never sure what to call it so I call it both. It was only available on the floor when the truck was first released in late 1947. There are several details that are different on this release than from other years. Even the the gauges and speedometer were in a different housing.
