| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 140 | Bed almost ready for paint. Not long now and I'll be cruising. check out the latest pics here. http://www.flickr.com/photos/86936723@N04/ | | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | That's a great looking truck! Well done! | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Wow! Nice work all the way!! | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Good design and execution work kiwiwilly. Looks flawless.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Beautiful work! Love the color!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Looks great! How did you make the flames? Mike B  | | | | | Joined: Sep 2007 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 140 | Thank guys. Mike B the flames were drawn out with a pencil onto flat alloy panels then swaged in by hand with a bead roller
Cheers Willy | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Willy, How many hours do you have in the metal shaping on the flames? Looks great, can't wait to see the finished product. Mike B  | | | | | Joined: Sep 2007 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 140 | Mike swaging the flames was done by a friend of mine with a motorised bead roller with a foot controlled pedal to vary the speed of the rollers. I'm not sure how long it took him but he only charged me $260 to do all four panels. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I cannot figure out how to see the pixs. I tried typing in the link, but no luck.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | old gold, you need to highlight the address, then copy it and paste in the address bar, or try from hereBill | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Red58, Thanks for the help. Awesome work!
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Sep 2007 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 140 | Highlight the link then copy and paste to your address bar
| | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | YOU, Are a true craftsman,and artist. Excellent work!! | | | | | Joined: Sep 2013 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 61 | That's amazing. Really great work.
Whenever you leave behind failure that means you're doing better if you think everything you've done has been great you're probably dumb -Louis CK- '53 GMC | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | | | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | Great looking work. Is that a propane set-up for fuel? | | | | | Joined: Sep 2007 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 140 | Great looking work. Is that a propane set-up for fuel? Yes propane or LPG as we call it here is only .98c per Litre whereas 98 octane petrol is around $2.19 so It will be much cheaper to run and the bigblock just seems to start and run much better on it than the crap fuel they are selling at the pump these days | | |
