7 members (Jims46, Otto Skorzeny, dt235sd, 2-Ton, tclederman, Bill Hanlon, Millenimech),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,191 Posts1,057,365 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | I hope to somehow get to the bottom of this, so I can move on - - My truck is 12 volts. All of the really cool (old) fog lights - like Guide - are of the 6 volt varity.
How can I blend the two together to make them work? | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Does this style of foglight work for you? Kanter Auto Products Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | change your builbs and lights to 12, put resisters in also 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Yea, i'd just switch the bulbs to 12v bulbs.. if they're old school lamps, the globes are likely to be glass, so you won't have to worry about the brighter, hotter bulbs melting any plastic.
| | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Thanks Niagara - The link was cool and those are nice fog lights from Kanter but, I am hopeing for some 1949 period correct "Guide" fog lights - or something with more of an old school look. Thanks mikes 63-k10 - What kind of resisters would you recommend? Thanks Fumblin46 - Do I have to do any modifications to the 6 volt bulb sockets to allow them to seat the 12 volt bulbs? | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hi Mike (63-k10) P.S.- I really like your truck  You've got quite a little gem there - she looks good! Did you & your dad do the 12 volt conversion yourselfs? I've just recently bought a Fulton sunvisor just like yours too! Are they very hard to put on?? Tom (49 Panel) | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tom, The fog lights you are searching for probably take a sealed beam lamp instead of a small replaceable bulb. I have enclosed a link with lots of lights, maybe you'll hit pay dirt. http://www.taillightking.com/fog_Driving_lights.htm Stuart | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | I have vintage Allstate fog lamps on my truck that use sealed beam bulbs. I got my 12 volt ones from the link below. They have guides that allow you to check the dimensions and wiring so you are sure you get the right fit. http://www.atlantalightbulbs.com/index.html | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | THANKS ATOMARC!! That's a GREAT site Thank you very much - didn't hit pay dirt yet...but with help from you all, I'm gettin' close...! Tom (49 Panel) | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hi 49 geezer! Were your vintage Allstate fog lamps 6 or 12 volts?
Is your truck 6 or 12 volts? | | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | You might just try to run them through a small DC step down transformer too. It would be similar to the resistor idea, but a slightly different approach. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I don't think you can step DC voltage down with a transformer. Alternating current has to be in the equation somewhere for this to work.
Stuart | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Yep. Resistor or if they are seal beams wire in series. | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Toms49; Sorry, just got back online. My lights were 6 volt originally. Cross-referenced the style on the Atlanta site and got the 12v bulbs. Amber and a perfect fit. Sold the 6v ones on ebay. | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hi 49 geezer So, if I understand what your saying, you switched out just the amber bulbs from 6 to 12 volt - and the 12 volt bulbs fit in the 6 volt chrome housing? | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Yep! The 6 volt sealed bulbs fit perfectly in the housings. Did you try looking on the Atlanta Bulb site to see if you can match up your bulbs with 12 v ones? I can post the part numbers of the 12v ones I got if you need me to. | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Just received 12v amber bulbs from Chevy's of the 40's today to replace my 6v bulbs.
The bulb received is a GE 4412A Fog ROHS and fits perfectly. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | My bulbs are Phillips 4415A. | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hi Down2sea & 49 geezer! How are you guys doing? Thank you VERY MUCH for replying to my post & for trying to help me out! I appreciate it very much - THANK YOU! 49 geezer - I did go on the Atlanta light site ealier in the post when you first told me about them (sorry! I should have posted to you that I went on there). It's a good site & I am going to add them to my favorites. Thanks for the Phillips part # too! I'll keep it for a reference later (I still check ebay all the time for fog lights & there's just nothing out there yet). Thanks Don (Down2sea) also for your part #GE 4412A - I will also keep them as well for a reference  Now if I can just find some nice housings.....? Tom (49 Panel) | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hi 49 geezer I just went to the Atlanta Light website & on the site they have a quick search box. I pasted in your description (Phillips 4415A) and the message says no items found? | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hi Down2sea The same thing as above just happened to me with your site!? I went to Chevys of the 40's and type in your description (GE 4412A) and I also typed in (GE 4412A Fog ROHS) and that website says there is no product match found? Tom  | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Okay guys, here is the order number from Chevs of the 40's: 987263A and here's the Link Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Toms49; Here's your link. Once there, type 4415a in the search box. It'll take you to the bulb page. http://www.atlantalightbulbs.com | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Thanks for the help guys!
I'll try these links out...
Thanks! Tom | | |
