4 members (Robert Crandall, farmallb, Steelonsteel, Rick Brown), 149 guests, and 5 robots.
Topics128,108
Posts1,056,239
Members48,437
#999394 01/15/2014 4:39 AM
I have a 66 1/2 ton and want to put disc brakes on the front. What is the best way to do this?
I have also read that the front axel assy. from a mid 70's to mid 80's 1/2 ton would almost bolt (maybe drill a couple of new holes)up to the 60-66 chevy frame, that way the disc brakes and everything would be there already.
Any suggestions or ideas would be appreciated.
I know a guy that used the 73-87 front end as well. As you said, I think it was mostly bolt-in, and works very well for him.
My 46 GMC on Photobucket
Replacing the cross member and associated parts is more work but then EVERYTHING is one year model. You can do it a bit at a time from junk yard donors, but this isn't my favorite approach. Either swap the cross member or Everything off one truck. either way, you'll have to replace worn parts. This is a great time to go to power brakes and power steering, too. If you can find a pair of 71-72 axles they'll give you 5 lugs all the way around.
best wishes,
Les
There are many kit available online, to convert your 6-lug, 1/2 ton Chevy truck from drum brakes, to front disk brakes. We have used the kit provided by Classic Performance Products.
www.classicperform.com
We purchase the complete kit, including upper & lower ball joints, spindles, calipers, pads, soft lines, inner & outer wheel bearings, inner & outer tie rods, adjusting sleeves, power brake booster, dual chamber master cylinder, proportioning valve, mounting hardware & installation instructions.
Considering the time & effort, to locate, procure, pull, refurbish, install & troubleshoot, we go with new equipment. When it comes to Start, Steer & Stop, we prefer new over used.
