1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99928 03/18/2007 1:19 PM | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | driving a vehicle putting out 18 volts when the accessorys are designed for 12 volt (13.8) could seriously affect lifespan of your accessories. Your cd player may have overload protection so the display will turn itself out. did the mechanic load test the battery when he tested voltage in. ? sometimes a battery will be bad from new. I don't know about generators but when we have bad batterys at work the volt gauge will show high charging rate at all times when running as the alternator will try to charge the battery with the bad cell. and the battery with the bad cell will drain the others as we have 3 or 4 hooked together. | | |
