a little help please. I'm stumped. I have removed gas tank sender unit to replace gasket so I though I should check unit. hooked up guage to positive on battery..hooked top of sending unit to other side of guage and ground wire to negative on battery. Gas guage reads about 1/4. when I raise float lever up which should read full it actually reads less than 1/4 on guage. any thoughts???
