| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | How do you propose to get the cylinders clean after the hone job? Unless it is scrubbed with a stiff-bristle brush and HOT (virtually boiling) water and lots of strong detergent, then rinsed repeatedly with HOT water, there will be enough honing grit left in the cylinders to wear the rings out in a matter of a few hundred miles. I wore out a set of rings on a 2500-mile trip from California to Tennessee after an in the frame rebuild, and I had cleaned the cylinders with lacquer thinner and terrycloth toweling until no dirt showed at all on the rags. Still not clean enough! Jerry
