0 members (),
67
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Unless you remove the block drain plug(s), you won't get all the water out, so mix the coolant a little strong on antifreeze when you refill the system. A stovebolt six has a block drain on the driver's side near the back, and the V-8's have one on each side, centered in the block just above the oil pan rail. You might have to poke a wire into the hole in the block to clear the sediment away if the block hasn't been detail-cleaned recently. Jerry
