Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Crimson48, J Lucas, Otto Skorzeny, Phak1, 1 invisible), 45 guests, and 1 robot.
Topics128,007
Posts1,055,275
Members48,418
#996569 01/03/2014 8:56 PM
I just installed a new radiator and thermostat in my truck. The cooling system was flushed before I pulled the old one out. Would it be OK to run tap water through the system to test for leaks than draining it before filling it with anti-freeze?
This is my first radiator install. Hopefully the last.
Thanks.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #996575 01/03/2014 9:09 PM
Water works just fine for a leak test and to see if the thermostat is good. Just drain it out when you are done. It will freeze. Water is my choice just because it won't hurt the environment if it does leak and...it is cheap. But don't forget to drain it out when the test run is over. Antifreeze will help protect the water pump and it it is better at heat transfer than plain water. Also will provide some corrosion protection with the different materials encountered. Did I mention the thing about freezing? Yes use water just don't forget to drain and replace. smile
Steve H
MarkT #996590 01/03/2014 10:37 PM
Thanks Steve. I appreciate it.
MarkT #996596 01/03/2014 10:52 PM
Unless you remove the block drain plug(s), you won't get all the water out, so mix the coolant a little strong on antifreeze when you refill the system. A stovebolt six has a block drain on the driver's side near the back, and the V-8's have one on each side, centered in the block just above the oil pan rail. You might have to poke a wire into the hole in the block to clear the sediment away if the block hasn't been detail-cleaned recently.
MarkT #996693 01/04/2014 6:19 AM
Will do. Thanks Jerry.
