1 members (TooMany2count),
119
2
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the 46 has a truck bellhousing on it you can use it and your 4 speed will bolt right up. If not just use your bellhousing.
It makes little difference if it is a 216 or a 235. Later 235's are not drilled for the front mount, and 1955-62 engines will need water pump adaptions. 1960-62 engines dropped the throttle pivot position needed. All easy fixes.
See the USA in your vintage Chevrolet! My Blog | | |
