DOT 5 is factory fill on Harleys, as well as several other motorcycle brands. Their brake systems are designed to be used with it. The brake systems in passenger vehicles and trucks are not, unless you convert them with DOT5 compatible rubber components. Best bet is to stick with what the manufacturer designed the system to work with if you use oem replacment parts.
Bill Burmeister
