| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | Yes you need one of them. The bearing or bushing goes in the end of the crank and accepts the main shaft of the transmission. I have never done the T-5 trans swap. But you will need to have a bearing (if available) that is the the right size to fit into the crank and the correct inner diameter to accept the transmission shaft. I am sure that there is someone here that has done what you're doing and will chime in.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
