I was found this post while researching .... "The manual says to pack the groove inside the sleeve of the bearing with grease". I was concerned because I didn't do that. If its really important I can pull the transmission and get some lube between the throw out bearing and the transmission shaft (I have not started the truck since installing the transmission). How big a deal is it?
Joe
1955 First Series 3100
