8 members (carbking, 3B, msmall, Bill Hanlon, FrankenChevy, walter74, Stovebolt48, Shardean),
58
2
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#9806 01/11/2003 12:45 AM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | 63-your truck has a vacuum advance distributor, right? Just find out where it taps into the manifold and get a double fitting to go there. My '72 Malibu (with 307 V-8 and points) had a fitting at the back of the intake, which had a large opening for the brake booster and a smaller opening for the vacuum advance line. Try scrounging at your local boneyard-a V-8 powered vehicle should have what you need, or you could also look at newer I-6 powered trucks/cars too. Hope this helps. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
