I removed fan belt and harmonic balancer seems to be tight all bolts I can see after flywheel cover was removed look tight. The crank was one thing I was thinking of also. I guess I will need to remove the oil pan and see if I can see anything else. Thanks for the reply!!!!!!!!!
