The cap is new and the plug wires were replaced a couple years ago.Another new rotor will be here tomorow.Ive even put the plug agains the engine where the ground wire is conected with my finger on the end of the plug and touching ground and not a tingle.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
