Brian,As you said there is one red and one purple and a brown wire and a two color (white and brown?) to the ign. switch. It was that last one that burned
I discovered that it was cut by PO at the firewall so it went nowhere. I dont know if the brown wire goes to the fuse box and then to the solenoid. How do I connect the wire from the neutral switch to the ign.--at the fuse box? and do I need a seperate wire from the neutral switch to the solenoid? The fuse box must be the origional--it has 4 fuses but there are spaces for more. Jim
