1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Something similar happened to me recently with my Corvair. I replaced all the ignition components, started it up and it ran great. Jump in the car for a test drive and after about 3 miles, the engine died at a stop sign. Would not restart. I assumed I was out of gas (I was on my way to fill it up). My wife brought me the gas can, added a couple gallons and the car started right up. Filled the tank and drove around some more, then same thing happened...just died at a stop sign and would not restart.
Eventually tracked it down to a BOOB (Bad Out Of Box) condenser or coil (replaced both at same time). Once one of those two components got hot, the spark went weak and engine would not run/start.
So, maybe you have a similar issue with your ignition components. | | | |
Entire Thread
1959 Chev 235 engine stalls at stoplight, turns over, wont restart
| apache3600 | 10/09/2013 2:52 AM |
Re: 1959 Chev 235 engine stalls at stoplight, turns over, wont restart
| Jim Sears | 10/09/2013 3:10 AM |
| truckernix | 10/09/2013 3:17 AM |
| apache3600 | 10/09/2013 6:21 AM |
| Tommy | 10/09/2013 12:32 PM |
| Jim Sears | 10/09/2013 1:59 PM |
| DavidF | 10/09/2013 2:40 PM |
| apache3600 | 10/09/2013 4:51 PM |
| bartamos | 10/09/2013 5:10 PM |
| Tommy | 10/09/2013 9:57 PM |
| Pre '68 Dave | 10/09/2013 11:36 PM |
| bartamos | 10/10/2013 2:59 AM |
| apache3600 | 10/18/2013 3:29 AM |
| Hotrod Lincoln | 10/18/2013 3:52 AM |
| bartamos | 10/18/2013 4:28 AM | |
