Here's anaother voice in the choir...check all of your grounds. I had to run a dedicated ground wire to each light, solder it to the socket and then connect it to the frame with a small bolt. I could never find a reliable ground through the sheetmetal.
Daily Driver 63 C-10 LWB Fleetside
