If your not setup to check it, it will be difficult. You need an air compressor with a good regulator, adjustable from 0-60# plus or minus a few. A 75 ohm pot to check the fuel guage. Is it an amp of volt gauge.
Larry
I don't own a vehicle that isn't old enough to drink.
