| | | Forums66 Topics128,276 Posts1,058,440 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97343 09/27/2006 5:53 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | these truck radios ain't hi fi home stereos
audio is an AC signal of varying phase or "polarity", not DC - a truck speaker has 2 connections, one [either one] goes to a jack or terminal on the radio, one [the 'other' one] goes to the radio case or "common", usually using a "ground" near the speaker if the radio is mounted to the metal cab - as wrenchbender sez, "polarity" will have an effect with respect to stereo sound .... if you have multiple speakers they should all be hooked up the same or the "out of phase" condition created makes for dull sound .... OTOH, the original speakers in these trucks were not marked + and - as it made no difference whatever for the simple non-stereo system - the cone pulls in when the audio waveform signal tells it to, pushes out for the same reason, and you want multiple speakers pushing and pulling at the same time
Bill | | | |
Entire Thread
Easy wiring question, I hope
| HardyRestoration | 09/26/2006 2:49 AM |
Re: Easy wiring question, I hope
| liljay | 09/26/2006 3:16 AM |
| Flxible | 09/26/2006 3:55 AM |
| Rusty Rod | 09/26/2006 4:25 AM |
| atomarc | 09/26/2006 4:25 AM |
| Brendan M | 09/26/2006 5:53 AM |
| atomarc | 09/26/2006 3:42 PM |
| Flxible | 09/26/2006 3:50 PM |
| atomarc | 09/26/2006 6:02 PM |
| Tiny | 09/26/2006 6:21 PM |
| Toyvo | 09/26/2006 6:33 PM |
| Wrenchbender Ret. | 09/26/2006 11:00 PM |
| carolines truck | 09/26/2006 11:38 PM |
| Flxible | 09/27/2006 5:53 AM |
| atomarc | 09/27/2006 5:13 PM |
| 64fleetside | 09/27/2006 6:43 PM |
| atomarc | 09/27/2006 10:11 PM |
| Flxible | 09/28/2006 12:58 AM | |
