| | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | Big Trucks is right on with the plant and date codes stamped behind the distributor. The engine casting number should be the seven digit number on the block between the distributor and fuel pump. Yours is most likely 3769716. But go here for a list to decipher http://la.znet.com/%Ec1937/Cast.htm | | |
