1 members (J Lucas),
43
8
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is very common for the U'joint attaching bolts to come loose giving you a vibration. There is also a very common problem I see. The front of the torque tube where the bell slides becomes worn, as does the inside of the part of the bell that slides on the torque tube. In this case the vibration smooths out on hard acceleration as the torque tube lifts up in the front putting the U'joint back in line.
See the USA in your vintage Chevrolet! My Blog | | |
