Originally Posted by Ronnie Ray
I'm very new to Stovebolt and to most things mechanical, especially wiring. I am in the process of pulling off the front fenders of my ;47 Chevy pickup so that I can change out the engine. It could really use a new wiring harness at the same time.
Where do I look for a good wiring harness. What is a reasonable price. Tips, helpful hints.
Am I even posting in the right section.
Obvious a novice!
Thanks for your help in advance
Are you swapping to another 6, or do you want a V8? This will make a difference in what kind of harness you use. I used a Painless harness but mine was a hot rod application.
My 46 GMC on Photobucket
