9 members (Mike B, Gdads51, Sjm, TooMany2count, 52Carl, greenie-reddy, 78buckshot, Wayne67vert, Wally / Montana),
98
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,262 Posts1,058,331 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Only first and reverse gears are not helical cut gears in the 1937-39 transmission. 1940 went all are helical cut. All the gears and shafts from a 1940-46 PU will fit in a 1937-39 transmission but the splines for the U' joint got finer 1n 1940 so U' joint conversion is needed. This is an advantage if installing later 3.5 diff gears. There is nothing special about 1954 transmission in fact the main shaft is to long. Many of the parts will fit though: The cluster gear is the same from 1940-63. Low-Rev slider 1940-54. I could go on but it all depends on which way you go.
See the USA in your vintage Chevrolet! My Blog | | |
