I am trying to locate a good spot to ground my bed to the frame. Where do you guys think is the best spot? In other words, what bolt on the bed is a good bolt to ground from to the frame? May I ask the same for the cab? What bolt on the cab is a good bolt to run a ground strap from the cab to the frame? The engine seems to be a little easier to find a bolt on. I like the bottom bolt that holds the starter on the engine. It's down under and not so noticeable.
Joe smile
"Truckin' Around .......... Since 1937!"
My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.
Operators are standing by to take your calls!
