1 members (baldeagle),
27
3
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Dave. I read your info about a noisy new lifter. After how many miles will a new, tight hydraulic lifter break-in. I have one that is noisy until the engine reaches operating temperature, then everything is fine. I have noticed that 1,500 miles after complete rebuilt, the tight lifter is not at noisy as it was at 0 thru 1,000 miles after rebuild. Can I expect the noise to go away completely, or would you recommend replacing the lifter? It is hard to say how long it will take. If it is improving I would keep running it.I am assuming you grooved the bottom of your push rods?
See the USA in your vintage Chevrolet! My Blog | | |
