I have been looking for front lower gas shock mounts to put on my '48 1 ton. I have not had any luck wih Jim Carter or the othersupplies, and no hits in a parts wanted ad.
Is there someple else that you know carries them?
Has anyone every tried to splice the 1/2 ton gas spring mount with the 1 ton lever action mount?
