Correct, the "nut" is a rectangular bar with tapped holes for both bolts.
Some penetrating oil and lots of torque is you best bet. Even if you break off a bolt or two you'll be OK in the end, they and the nut plate can be replaced. If it comes to it, with the nut plate out you can probably remove the broken bolts.
