Definitely drain your gas out of the tank. It's going to be the most foul, rotten stuff you'll ever smell, and it won't work in your engine. If you need to start a bonfire, on the other hand...
Clean the carb, and rebuild it. You'll be glad you did.
And strictly speaking, you don't need a starter so long as you you have your arms and a crank. grin
1946 Chevrolet 3600 - "Old Number Seven"
Cavalry's Here. Cavalry's a frightened guy with a rock, but it's here.
