Britcon shows this as the white wire. When the turn switch is not on & the brakes are applied curent from the stop light switch goes through the turn switch to both stop/turn lights. When the turn signal is turned on it interrups & flashes the coresponding light. Understanding this helps diagnose the problem. I believe the colors are the same. I,ll look tomorrow when I,m at the shop.
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
