Originally Posted by Jim Sears
The vacuum advance moves the internal parts of the distributor, the outside doesn't move.
The vacuum advance unit on a 216/235/261 is attached to the outside of the distributor - you can see the distributor move. The mechanical advance mechanism (weights/springs) are inside the distributor and you cannot see them at work.
