| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Installed a temp gauge and sensor in my 58 Chevy. Manual gauge shows engine to run pretty consistently at 180 degrees.
When I hook up my temp gauge in the dash after about tem minutes it will be pegged out. Install the old gauge and it too will eventually peg out even with the new sensor.
If the wiring from the back of the gauge to the temp sensor is bad will it make it eventually peg?
