I had a lot of similar "gremlins" when I got my 61. It was a real pain in the a$$ for a while. One weekend I climbed under the truck and spent the days pulling out extraneous wires, it had a lot of farm rigged Git-R-Done type wiring done to it. I pulled out at least a hundred feet of wire, total, from under the dash, hood and bed areas. After that almost all of the gremlins were gone. A couple things that hadn't worked before now work and I learned a lot about how my truk is wired. I would suggest spending a day under your dash and becoming aquanited with what is under there. Some of the stuff I found was pretty scary and I am pretty sure I averted a major fire or two. At one place the PO's kid had put a CD player in and he just shoved the power wire into the back of the fuse panel and then screwed it back down! A lot of questionable and scary things can be done in the lifetime of an old truck. Good Luck!
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
