| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94545 02/12/2006 3:02 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | For a quick test:
Disconnect the negative cable from the battery and take a volt meter and measure between negative battery pole and the disonnected cable.
If there is any voltage you got something sucking at your battery.
Frank | | |
