1 members (Gdads51),
100
2
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | The position of the column in steering gear box can affect this. The cast piece under the steering wheel has to be free to move. Hard to explain. The center steering column is the negative return. The piece with the wire must be connected to positive and not touch ground. | | |
