| | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I don't know if this is your problem but when I replaced my vacuum wiper motor with an electric one from LMC, I also got a linkage problem that I couldn't correct with blade positioning. I can't remember the symptoms exactly but it seemed that one arm was too short. See the picture. I cut a piece of metal and put 4 slotted holes in it for adjustability. I then got brave and cut the arm and put round holes in it. Turns out that lengthening that arm solved the problem. - Adjustable wiper arm. - - 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
