1 members (Samantha), 45 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#941993 05/09/2013 12:05 PM
I have installed my wiper motor in my 49 chev. When the linkage is unhooked it runs fine. When I hook up the linkage the wipers push down towards windshield frame and it locks up. Could the arms on the wiper arm spindles be upside down? Iv'e run out of ideas. Thank you. Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
where is the new motor from?
is it electric?
vacuum?
You might need to remove the blade arms an re-position them.
The wiper motor was rebuilt by Ficken the wiper man. I have had the wiper arms off and the spindles turn, Then I shut the wiper off and let it park, Then reinstall arms, And it does the same thing and locks up.
I don't know if this is your problem but when I replaced my vacuum wiper motor with an electric one from LMC, I also got a linkage problem that I couldn't correct with blade positioning. I can't remember the symptoms exactly but it seemed that one arm was too short.
See the picture. I cut a piece of metal and put 4 slotted holes in it for adjustability. I then got brave and cut the arm and put round holes in it. Turns out that lengthening that arm solved the problem.
Adjustable wiper arm.
Make sure the transmissions arms are on the correct post.
Denny as always has some excellent pics.
...link...
I had a problem with the passenger side binding. I had the arms on the wrong post.
On the electric version you can adjust the park. Not sure about yours
Good luck
