1 members (delky),
86
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The 235 bell housing will not work on any V-8. If you wish to retain the hydraulic clutch you will need a V-8 bell housing from a 60-62 truck which used the hydraulic application. GM reverted back to manual clutch linkage in 63. I understand the hydraulic bell housings are scarce but someone on this site may have one. There are numerous aftermarket suppliers that offer engine mount cross members and kits. That would probably be cheaper & easier than finding other parts and having to modify them. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
