Quote
Originally posted by Ranger Ric:
i'm not sure of the cfm but it is approximatley 2 feet across the blades and mounted flush to the radiato.
What is your average / usual temp? What was your "warmer than I would like" temp? Might still be in range, might not.
I'm not saying this is your case, but some folks get comfortable with the needle sitting in one place. If it bounces up to the higher range of normal, they think there is a problem.
