| | | Forums66 Topics128,133 Posts1,056,395 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Might be the accelerator pump in the carb. When you look down the carb throat you should see a good stream shoot into the manifold when you push the gas pedal. If not you may need to rebuild that carb. Easy to check before you start adjusting things.
Ed
