I may have erred in saying I was putting in a fusible link. I meant to say I am going to put in an in-line fuse, one of those little nylon units that snap together with a separate fuse. The wire gauge and ampere I wrote about referred to what is available in those units. So to sum up, a 16 ga wire with a 15 amp fuse should suffice, correct?
