Guys,
This engine doesn't have a flywheel, it has a flexplate. We pulled the three bolts that hook it to the tranny to eliminate it and the torque converter as a problem.
No two piece seal.
We will do the pry bar test on the balancer and look even harder at the mounts.
No changes were made to engine prior to problem appearing.
Will get back to you soon, and again thanks for all the help.
