| | | Forums66 Topics128,113 Posts1,056,277 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | As you drive down the road the blow-by is sucked out the tube on the block. However when you are stopped it rises and comes out the valve cover vents. That is not unusual and is only a problem in excess. If the tube is plugged then it will always come out the valve cover along with a film of oil. | | |
